WHO IS WALKING WHO?
Here is how I made the frame:
A good neighbor walks her dog almost every evening, and her cat just follows along, as they walk. It is remarkable to watch. Thought I would practice doing a Drop Shadow frame with it.
This is how I did a Drop Shadow frame in PS CC.
(I have a "Layers Window" open on the right side of my PS workspace.)
1. Open image in PS, and right click on the Background Layer, and duplicate this layer. PS will put the duplicate layer (Background Copy) right above the Background layer.
2. Since the Background Copy is now "Highlighted" and active, left click on the original Background Layer, to activate it. You can re-size this image file now, if you wish, to your desired future file upload size.
3. Now, with the Background layer activated, add some white (or color of your choice) canvas space around the image, (Image-Canvas Size) so that when you make the Drop Shadow frame, it will show up nicely. (I used 8% of pixel width as the size to add to the width and the height) It was 96 pixels for my additional space, yours may vary.
4. Now, activate the Background Copy layer, by left clicking on it, so that it will be "Highlighted)
5. From the menu at the top of the workspace, click on Layer, Layer Style, and then Drop Shadow. You will get a pop out menu.
6. In the Drop Shadow Structure, I chose for this image, Normal Blend, 50% opacity, 130 degree angle, Distance 15, Spread 27, Size 27. I did not change anything else. Click OK, to accept it.
7. Now click again on the Background Layer, and save it.
As you choose the different settings, you will see changes taking place in your image frame....just play with the settings to see what they do, and make your own version of it.
There are LOTS of options...you could also set your choice of settings as a default in Drop Shadow Structure, or probably create an Action to do this for you each time.
I know this seems like a lot to do, but it goes much faster than you can describe it, and puts you in total control of what happens...or doesn't.
I am sure there are faster and better ways, this is just how I did it. I hope this is understandable...not easy to describe this stuff! LOL
