Which computer system are you using? Mac or Windows?I still can't access the oil paint filter. I switched to 8-bits/channel, and it is still the only stylized filter that is greyed out.
In both cases, you have to go under the Photoshop menu<preferences<performance and then check the box to use the graphic card and activate Open LC under the advanced menu of the graphic card options.
Hope this helps.
Well, after a bit of poking around, I found out that my version of MacBook Air had the Intel HD 3000 graphic card. And this specific card, of all the other cards supplied with different versions of MB Air, does NOT support the open CL... So I will have to forget using the oil filter with my notebook. Good thing I also have the iMac that has the whole thing working.
You have to check the allow Open GL in the advanced performance PS preference menu.My Late 2012 iMac has the GeForce GTX 660M gpu, but apparently won't allow the oil paint filter to work either. What the MESS?
Just looked it up online, and it supports OpenGL and OpenCL, so might mess with it again when I get home, try to sort something out.
@tea2085Carroll; I downloaded the raw camera plug in and downloaed 9.1.1 but now I don't know what to do with it. It is not showing up as an option in creative cloud. Paul
Adobe Camera RAW works as part of Photoshop, it's not an application you can launch directly. Associate the .NEF file type with Photoshop and then, when you double-click a .NEF file, Adobe Camera RAW will launch.Carroll; I downloaded the raw camera plug in and downloaed 9.1.1 but now I don't know what to do with it. It is not showing up as an option in creative cloud. Paul
