Re: Wud's project 365
Day 11. Shot 400 images of water drops, got angry, did this instead lol. I am a space cowboy!
Rough description of what I did in PS:
- adjusted the image, white balance etc, like you would do with any image
- copied the layer, desaturated it, layer blend: hard light, occupasity 84% (could be less, look at your own image)
- copied layer 1 again, placed it on top, filter -> other -> high pass, 7-8% -- layer blend: overlay, occupasity 40%
- adjusment layer: gradient map (black and white), layer blend: soft light
- adjustment layer: hue/saturation --- lowered saturation to -36
- placed 2 old images on top (one by one), layer blend: screen. One image was lens flare, the other blurred out bookeh. On the lens flare I drawed it up with a white brush.
- added gradient tool, red-no color, left top corner and into the middle (more or less)
I did one more - this is more or less the same work progress as above, but at the end, instead of adding other images:
- added a blank layer, with a big soft brush I painted with blue in the top right corner and down, in left side I painted with orange. Layer blend: screen
- new blank layer, drawing with 50% occupasity soft brush the same colors on top, but this time layer blend was color dodge. Did it several times, before I got it right...
- new blank layer: small dots in different colors, lowered the occupasity and made it soft light
Okay. I know. I suck at explaining but I go back and forth when I do it, so its a bit hard to keep track of.. Got around 20 layers.
