Tutorial - How to post images inside your post
Mike D90
I have not seen a real dedicated tutorial on posting pictures/images. Figured I would put one together and if it is worthy of a sticky then maybe it will make it.
Here is the proper way to post your images into a thread post or in a reply to someone else' post.
Preparing Images for Posting
- Your images do not need to be hosted on a site such as Photobucket or Flickr
- You will need to resize the image(s) you intend to post so you will need a photo editor of some kind
- IrfanView is free and easy to use and works very well
- The forum automatically resizes images that are larger than 1000 pixels in width
- Height does not matter
- Web images are displayed no higher than 96 pixels per inch in resolution so no need for 300ppi
- Images should be saved in JPEG format at a low to medium quality around 120kb in file size
- Read and follow any forum rules as to image content
How to Post an Image
- Create your new topic or click "Reply", when reading a current topic, to post a reply to someone else' thread.
- Once you have created the posting window enter your subject or topic name and the main message text of your post.
- Once you ahve entered the main body text of your message hit the Enter key a couple times for some space.
- Post your image below your text block.
- To place your image click the icon that looks like a picture frame
(see pic below)
- Once you click the icon that looks like a picture frame you get a new command window prompting you to choose your image(s)
(see pic below)
- Once you have clicked "Select Files" you will choose the tab to where your image is located which is usually "From Computer" if they are on your hard drive. If you have images stored elsewhere online you would choose "From URL" and you would enter the location of the image.
- Next you will get a new pop up window to browse your computer (see pic below)
- Now you will need to browse and locate the image you wish to insert into the post. Once you have located the image click it to highlite it and select "Open". This will place the selected image into the "Upload" window list. Then click "Upload Files".
(see pic below)
Mike D90
- Your image should now be visible inside the posting window.
- To set the size and alignment of the image put the mouse cursor over the newly placed
image and double click it.
(see pics below)
- This will open up a new window where you can choose its alignment for "None", "Left", "Center" or "Right".
- This aligns the image within the post window to what you choose.
- Select the image display size, "Thumbnail", "Medium", "Large" or "Full Size".
- Then click "Ok"
(see pic below)
- Now you can add even more images to the post, using these same steps above, or you can post your reply by clicking the "Submit New Thread" button or the "Post reply" button if you are replying to someone else' thread.
- Remember to hit "Enter" key after each image, if y ou are posting multiple images, so that there is a space between them and they don't touch each other and they align on top of one another, not beside.
- That is it!!
PapaST
Every time a new poster came on board you could always count on Don posting the instructions for posting photos. He will be missed. RIP Don.
Marilynne
I had trouble finding it. Thought I would post it here so it would be easier to find.
Thanks for posting this one Marilynne.
I wish I could find the original so I could post it on it's own. Could you tell me where you actually found it?
Don will be dearly missed...
Capture Date2013:05:10 12:26:07
Capture Date2013:05:10 12:27:06
Capture Date2013:05:10 12:28:08
Don's version.
Marilynne
I went thread by thread in the New Member Introduction thread until I found one. Then did a copy and paste. It's been a while since Don posted one.
Marcel, I found this post by Don from 2013. It might be the same post that Marilynne listed here.
https://nikonites.com/general-lenses/15196-50mm-help-3.html#post174586
Well it's here now so we'll keep it pinned on top of this subsection. If someone asks, any one of you can refer them here.
Texas
There's some forum software out there where you just drag and drop the pic into the message. Maybe this package will get an upgrade someday.
I don't know. I did ask our list owner @jedg about this a while ago. If I remember correctly, his answer was that we have too much stuff on the servers to make such a switch. But I too keep hoping for just that.
