Clovishound
Well, the Nikon 105mm macro lens I got for my daughter died today. It no longer focuses, either in AF or manual focus mode. When you turn the focus ring, the lens does not focus at all. I called Nikon, they said if I list the problem as "focus/zoom not smooth", the estimate will be be $475. He recommended I put it under "other" and explain the problem. If it goes in under the "focus not smooth", it will be a MINIMUM of $475. With the "other" listed, they will send me an estimate based on what the technician thinks the issue is and I will have to approve it. I will be repairing/replacing it since it died while I was using it, and it's my daughter.
I can buy a used replacement in LN- condition for $500.
A new 85mm DX Nikon lens for $560
A new Sigma 105mm new for $670
A new Tokina 100mm new for $429
The DX and Tokina won't work properly on my Z camera, although that is a minor consideration. I'm a little gun shy of using one of her lenses and having to fix/replace it.
I am reluctant to send it to Nikon, as it is unlikely I will be able to have it repaired for less than $475, and then I would be out time and shipping. By the time I pay shipping, I am pretty much the same as a LN used direct replacement from KEH camera.
What say you? Any other options?
No matter what, I guess I won't be doing any macro photography for a while, unless I get a set of extension tubes for my 24-70.
