What is the BIGGEST and FASTEST memory Card this camera can use ........ I wish to purchase a new one but cannot get a straight answer....hoping this forum can assist
Cheers
Your D90 is compatible with any SD memory card, regardless of speed or capacity. The speed limitation will come from the D90's buffer, not the SD card (assuming it's Class 10). I'd probably use a Class 10 card and something that can transfer in 80MB/s range. You can get a faster card if you want, but I don't think you'll see any difference in performance.
The largest SD card I am aware of, assuming you mean capacity, is the SanDisk Extreme Pro 1TB.
