Chris@sabor
Yes, so doesn't that prove that if you shoot the full frame will produce a better image if it can match the lower ISO in the dx?
Notice what they did there ... the upped the ISO 2-stops to ISO 800 when the closed down the aperture 2-stops to f/5.6. Or the reverse ... when they opened the aperture to f/2.8 (let in more light), the closed down ISO 2-stops to ISO 200 to accommodate. It's the same equivalent exposure.... they just traded aperture for ISO (or vice versa). Shutter speed remained the same, and focal length does not play a part in exposure.
Yes, I think that's exactly my point. He had to degrade the fx image to match the images of dx or micro 4/3s by the crop factor, if I'm understanding it correctly?
No. Tony's whole point in making that video is to get the same depth of field for a given image size with different sensor sizes. There is no "degrading" of the image, just cropping to match subject size and show depth of field. I like Tony's books and instruction, but I think he gets way to zealous about the f/stop crop factor thing he espouses.
I think Don has both cameras, maybe he would be willing to do a test at the longer focal lengths?
...But when you compare dx to fx doesn't the crop factor have to applied to the aperture as well?
The angle of light remains identical for both since that is defined by the lens. What differs is the amount of light that hits the sensor. For DX and FX the captured image is identical but the DX sensor only captures a portion of the FX image.
I have the D7100 and the D750. My longest lens is the 70-300. I will try to remember to shoot the D7100 at 300mm and then put the lens on the D750 and shoot at 300mm. then go home and crop the D750's image to the same view as I got on the D7100.
Did I get that correct?
Just for fun, not very scientific, and not the best subject, but i did a similar quick 'experiment' with crop factors earlier this year. Taken with a D810 and then a D7200. (Exif may show the D7200 photo as a D810, it wasnt. Software recognition error. Full exif shows last photo as 700mm equivalent)
D810 Uncropped
D810 Cropped
D7200
You are absolutely wrong. What comes out of the ass of a lens is the same regardless of what the lens is connected to. The sensor contains numerous targets and each target gets the same light intensity regardless of the size of the sensor. The new 50mp + sensors on the canons (and soon to be nikons) is nothing but an oversized dx sensor.Taking megapixels out of the equation; the general rule is that for the same quality of signal as an FX you need about twice the amount of light with your DX.
That matters most when there is less light.
