flash sync with remote
johnnyg666
Hi, could someone please advise. I am totally inexperienced with photography. I have got a D5000, a speedlight SB 700. I am trying to use the flash off camera but I can't sync it with my Nissin Air 1 remote. Could someone advise please. Thank you in anticipation.
Fred Kingston
I don't think that flash will work with that trigger. That tirgger is a radio trigger and uses 2.4mhz... that's a radio signal... That SB 700 uses Nikon CLS which is NOT a radio device but uses a series of flashes from the Nikon CLS system controllers... IOW, they're two different technologies...
I'm assuming you know for sure the Air 1 commander you have is spec'ed for Nikon (versus Canon, Sony, etc.) But do you also have a Nissin Air R trigger attached to the SB-700? Because you need both a transmitter (that's your Air 1 Commander) and a trigger to operate wireless off-camera flash using an SB-700.
As @FredKingston mentioned, Nikon's CLS operates completely different. You might need to buy a Nikon commander flash as what I'm reading indicates the D5000 doesn't support CLS. No additional receiver is required providing you are using a Nikon made flash that supports CLS (which your SB-700 does). But I'm pretty sure you would need to purchase something that acts as a Nikon commander flash to fire your SB-700.
https://www.nikonimgsupport.com/ni/NI_article?articleNo=000001751&configured=1&lang=en_US
And as Horoscope Fish said, your other brand trigger (meaning anything other than made by Nikon) needs to be matched with a identical brand receiver that is attached to the bottom of your SB-700.
Below might be the receiver that goes with your current trigger, but please check to make sure it is the correct compatible receiver.
https://www.bhphotovideo.com/c/product/1235476-REG/nissin_ndar_n_air_r_receiver_for.html
johnnyg666
Thank you to everyone for your help and advice. I probably should have read up more about it before purchasing. It also looks like I now need to spend more on a trigger. Thanks again.
Do you live in the continental USA? If so, I have a trigger/receiver set I can send you at no charge. Let me know!
johnnyg666
Hi,thanks for your help. I have purchased an Air R to go along side my Air 1. Both Nikon, I may add. I have paired them but still the SB 700 doesn't react. 'm at my wits end with this and I'm feeling pretty stupid about it. Am I missing something simple? Do i need to change any settings on me D5000?. Thank you.
johnnyg666
Thank you for your kind offer. I am in the UK. I have purchased an Air R but even though they are paired, the flash SB700 isn't responding. Thanks again.
johnnyg666
Sorry guys, I feel so foolish. I had the flash set to Remote, rather than Master. I really do appreciate all your replies and thank you for your kind help.
johnnyg666
Once again a big thank you to everyone.
Hopefully if anyone is as stupid as me in the future, we can help them. Thanks guys n gals. Cheers
