taylor
Hi, my D3400 went dead yesterday during a close macro shot. I was using live view to check focus then I noticed the screen froze. No button works. Even the on-off switch does not work. I took the battery out. The screen went off. But when I put it back in, the screen will no longer turn on. I can see a "err" light and the flashlight icon flashing in the view finder. When I press shutter, it will release. But no files are saved. I tried P and M mode and random buttons but could not get it to work.
Any one ran into the same issue before. How did you fix it?
Bikerbrent
I don't own this camera, but I am sure someone will be along shortly to help you out.
Andy W
Welcome to the forum! Is the battery fully charged? Have you tried another lens and SD card?
I found and old thread about this problem:
1. Switch to Live View-If the monitor works and many of the controls come back, you know the camera is probably OK, Otherwise a trip to Nikon Service is in order.
2. Try every control and button on the camera while in Live View. This way you confirm that they are all OK (or not)
3. Find a sticky button. In my case it was the depth of field preview button. Pushed partially down and won't come up. I never pushed it but possibly i depressed it by accident.
4. Free the button by gentle prying with a fine knife blade and clean with alcohol.
Read more: https://nikonites.com/d5100/4389-screen-black-err-3.html#ixzz6Iv9HSiMe
taylor
Thanks Brent and Andy for the Welcome!
Andy,
Thanks for the tips! The battery is fully charged. I tried different lens and SD cards and still the display would not work. The error I see in the view finder now is slightly different. The blinking icon for "flash" disappeared. Instead, a blinking question mark appeared...
I am still trying the buttons.
Andy W
According to the link below, the blinking question mark is telling you that you need flash.
The camera does give you a little flash input, though: You see a blinking question mark or a flash symbol, or both, in the displays if the camera thinks you need flash.
Press the Zoom Out button (the one with the question mark above it), and a message appears, recommending that you use flash.
https://www.dummies.com/photography/cameras/nikon-camera/enabling-disabling-flash-nikon-d3400/
taylor
I think you are right. The blinking flashing or question mark were both indication of needing flashlight. I was using an old AIS lens in door when I switched to the AF-P 18-55mm and rotated the dial to "auto", the flashlight fired. So perhaps that is not part of the problem.
The "Err" is still there though. I found this article on a similar problem on D3300. The problem was solved by a new SD there. However, I tried different SD cards and was not able to get around the error.
https://www.reddit.com/r/Nikon/comm...screen_suddenly_stopped_working_wont/dj6fej3/
Marilynne
Welcome!
This is an old thread. You may not get a response from the original poster.
Also, please feel free to introduce yourself here - https://nikonites.com/new-member-introductions/
@taylor
Template Compilation Error
