My LCD screen shows some information such as the memory cards and various other things but not the same info as when the camera is turned on. I wonder if you've made a change in the preferences that is now causing it to show this data. If you don't want the data to show up or you can't find a way to alter the read out, you might consider re-setting the camera back to factory settings.
