See HERE
f you've had that Nikon D600in your online shopping cart waiting for a housing to hit the market, you better get your credit card out! Nauticam announced today the arrival of their much-anticipated NA-D600Aluminum Housing for Nikon's latest full-frame DSLR. Nikon's D600 is comparatively easy on the wallet and is extremely attractive to underwater photographers because of it's FX (full frame) 24 megapixel sensor, its higher ISO capabilities, 100% coverage viewfinder, and the ability to use all the DX (cropped sensor) lenses in DX-Mode such as the popular Tokina 10-17mm Fisheye.
The Nauticam NA-D600 sports several hallmark features that have made Nauticam an industry-leading housing manufacturer. The housing will feature the great ergonomics, easy loading/unloading, and their unique Locking Port Release System that users have come to expect.
Like the recently released NA-D800 housing for the Nikon D800, the NA-D600 has the dual paddle assemblies that put the Video Record, AE/AF-L, Playback, and ISO within thumbs reach. Of important note to video shooters is the easy access to the Live View button and Live View Selector. Nauticam is especially proud of their ability to access the Release Mode control allowing the shooter to lock in the D600's "quiet" shooting mode when dealing with skittish subjects.
It goes without saying that the NA-D600 can be used with the whole line of Nauticam Ports and accessories. The housing ships with a single Nikonos bulkhead which can be switched to S-6 or Ikelite. For optical triggering, the NA-D600 of course features Nauticam's fiber optic system that is compatible with Inon and Sea & Sea strobes.
Detailed Info for the NA-D600 Housing:
Specifications
* Depth Rating: 100m
* Dimensions (with handles mounted): L 350mm x H 189.5mm x D 132mm
* Weight: 2.7kg
Standard Features
* Patented Locking Port Release Lever
* Sensitive Two Stage Shutter Release Lever
* Optical Strobe Connectors
* Rubberized Ergonomic Grips
* 1 Customizable Accessory Ports (allowing use of optional Nikonos, S6, or Ikelite Strobe Connectors, Hydrophone, Video Out, or Remote Control Connectors)
* Embossed Control Function Labels
* Quick Release Camera Mounting Shoe
* Lens Release Button
* Four Strobe & Accessory Base Mounting Locations
* Complete Access to All Key Camera Controls
* Stainless Steel Support Brackets for Handles
* .66x Optical Pickup Finder (Enhanced 180 deg and 45 deg Viewfinders with External Diopter Adjustment optional)
* Audible and Visual Leak Alarm
Model Number: 17210
To find out more, read the original press release from Nauticam below.
Specifications
* Weight: 2.7kg
Standard Features
Model Number: 17210
