lostnomore
I just watched this excellent dpreview test of the D750. Very insightful! I've got some new settings to check out, that's for sure.
I'm quite certain they shot everything in RAW during the first half, and then during the second half they pulled all the details out of the deep shadows while post-processing the RAW images to get their final images. So them using highlight-weighted metering, flat profile, etc while shooting allowed them to achieve this. There's absolutely no way they would have been able to pull that amount of shadow detail out of a JPEG file.That is a great review. Kind of confusing in places till I realized the were talking about shooting in JPEG.
As I understand it, you can use different WB settings when shooting RAW but you're not actually affecting the RAW file itself. The WB information you've chosen in the menu is simply being recorded and appended to the RAW data. You would be able to change the WB at any time during post' because you've not actually affected the data.That is a great review. Kind of confusing in places till I realized the were talking about shooting in JPEG.
One thing I am not quite sure of though is that when you are shooting in RAW the LCD playback is showing you the Processed JPEG version. Am I correct in that assumption? If yes then you could use ADL High and flat profile and other improvements to show you more of what you could possibly get once you Process your RAW file. I know that when I look at my shots on the camera they tend to look rather lifeless. It would be nice to get them to look a little better.
I did find out recently that the White Balance is affected in the RAW shot. I did not think that any of the controls did anything to the RAW file. Is there anything else that does change the RAW files?
Using Camera RAW, I can apply any of the Nikon Profiles (Landscape, Vivid, Portrait, Flat, etc.) to any RAW file, regardless of what settings I used in-camera; they're just presets. I can do the same with WB; the options are just presets I can apply if I want to. Maybe I forgot to change the WB setting one day and I accidentally took a fantastic shot using the "Tungsten" WB preset on my camera while outdoors... No problem, I just change the WB setting from "Tungsten" to "Auto" or "As Shot" (or any other preset or adjust it manually) while in Camera RAW.
Again, as I understand it... RAW data is just that: RAW data. We can apply all the "settings" we want in-camera to save time but in the final analysis, it's still just RAW data and all of those presets are appended to that data to help speed up our workflow.
I understand all that. I was just surprised that adjusting it in camera showed up when I carried it into Lightroom or Photoshop without me setting or applying anything
