the toshiba exceria pro with nikon d7100
nikonos
cause of big image size the buffer getting full after 5 images on raw .. if i will use the toshiba exceria pro 260mp/s writing speed will it change something?
Fred Kingston_RIP
Probably not significantly.... you might go from 5 images to 6 or 7 images... If that's acceptable, then buy one. There are other through-put factors related to the OS than just write speed of the disk...
I doubt that you would see any difference over a decent class 10 SD card. The limiting factor for the most part is not the Card but the camera. It can only write so fast and no matter how fast the card is it just won't make any difference.
