Hello
This is my second post here and first on the D90 thread forum
I need some help with sorting the direction of the dials
I currently using the front dial as Aperture and the second dial (the one at the back) as shutter speed
Both react to positive or larger values when I move the dials towards the right -->
And to negative or smaller values when I turn them to the left <--
If I want a faster shutter speed the back dial will move to the right -->, if I want a larger value aperture (say from f2 to f4) I move the front dial to the right too -->
This is good and this is how I want it
However: here is the question
If i want to change the Exp Comp +/- to a higher value (Say from 0.0 to +0.3) The back dial has to be moved to the LEFT!!! <--
Same if I want a negative value say from 0.0 to -0.7 the back dial has to move towards the RIGHT -->
This drives me crazy as I feel is completely counter intuitive
Is there a way to Fix or Change this?
Thank you in advance for your help
