Today the EXIF data output was improved a bit. It is now more readable.
In addition, I've added Lens data if it is available. For example, If you run your images through Lightroom, lightroom should append the Lens data to the Exif (it is normally encoded, and doesn't output the literal name of the lens)
Here's an example of the full Exif data being displayed:
Amsterdam - Nikonites Gallery
Keep in mind that the system can only display what is available to it. If your image doesn't have exif data then it cannot be displayed. This sometimes happens when your run your images through a program to process them.
If you see any weird data being output please report it here.
