Got this camera a week ago, I've noticed the d7000 seems to produce more cyan/green/yellow tint photos, while the d40 produces more brown/magenta tint. All the same settings/lens/exposure/etc. Don't matter if I view in NX2, lightroom (unaffected by picture controls), JPG, RAW. Even syncing the white balance in lightroom doesn't make them the same color. Tweaking the WB magetna on d7000 helps a bit to remove the green, but then whites become a bit pink. My monitor is calibrated with spyder and I see it on the camera LCDs to.
The d7000 seems more accurate, but I don't like the slight green/yellow tint I'm getting in alot of photos. Why isnt the WB the same between them? Anyone else notice this with your camera colors being different from other cameras even with every setting/exposure/wb the same? Should the d7000 look like this?
D40 Incandescent light/WB: Gray backdrop is magenta.
D7000 Incadescent light/WB: Gray backdrop closer to neutral but slightly.
D40, Daylight light/WB: Trees brownish, darker sky.
D7000, Daylight light/WB: Trees green, snow yellow, more cyan in the sky.
