Z5 ii Battery Consumption
Hi. New member here. My new Z5 ii gobbles up 25% of a fully charged battery (EN-EL15C) in just one hour.
Nikkor 50 F1.8 S or 24-120 F4 S attached, with lens cap off. LCD left on the photo shooting screen throughout, and with brightness set to MINUS 2. Airplane mode ON. Energy Saving (photo mode) ON.
The camera is new. The cell is new and with fewer than 10 recharge cycles on it and in perfect condition per the camera.
When I explore the menus, it seems like the camera runs down the battery even faster.
Is it, and other Nikon Z models for that matter, supposed to be this power hungry, or I have a faulty camera?
Thanks in advance for your assistance.
BF Hammer
Mirrorless (all brands) consumes more power. For that matter, using Liveview on a DSLR consumes large amounts of power also.
It is why Nikon upgraded the EN-EL15 with more capacity to the C revision. It is recommended to buy a backup.
Paliswe
New batteries has to go thru a number of charge - discharge cycles before they reach full capacity. Discharge the battery quite a bit, before charging it again.
As mentioned above, it is recommended to buy a backup. I have two batteries which I switch between.
Thanks for the tip. I didn't know li-ions behaved like that. Both cells have gone through only several cycles of FULL discharge (camera forced shutoff). Strange why the camera always recognizes both batteries as at 100% fresh off the charger, if they in fact haven't reached full capacity.
Paliswe
Make sure that you have turned everything off in the network menu, so that they don't drain the battery. I have all those "wireless" functions turned off.
