Photography Q&A
Would appreciate some help and advice
<blockquote data-quote="Vixen" data-source="post: 420167" data-attributes="member: 21839"><p>You can tie one end of the string to a bolt the correct size to fit in the tripod mount on the bottom of the camera and the other end to a large steel washer (makes it easier to hold down with your foot). You need to just make the string the right length for you to hold the camera comfortably to take the shot with the string taut.</p><p></p><p>You can't get long shutter shots like this tho, putting your camera down is the best option <img src="data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7" class="smilie smilie--sprite smilie--sprite8" alt=":D" title="Big grin :D" loading="lazy" data-shortname=":D" /></p></blockquote><p></p>
[QUOTE="Vixen, post: 420167, member: 21839"] You can tie one end of the string to a bolt the correct size to fit in the tripod mount on the bottom of the camera and the other end to a large steel washer (makes it easier to hold down with your foot). You need to just make the string the right length for you to hold the camera comfortably to take the shot with the string taut. You can't get long shutter shots like this tho, putting your camera down is the best option :D [/QUOTE]
Photography Q&A
