Nikon DSLR Cameras
D7200
Why ISO is so high when using flash on Nikon d7200
<blockquote data-quote="aroy" data-source="post: 573248" data-attributes="member: 16090"><p>The flash behaves differently in different Exposure modes at least in my D3300 (and I think it will do so in most current bodies)</p><p>. When using Auto ISO, in Matrix mode, as the camera uses flash as a "Fill Flash" (default setting), the body calculates the exposure for ambient light hence high ISO. At fixed ISO this is not the problem, as the flash will output enough power to light the scene.</p><p>. In Spot mode the flash works as a TTL flash, its power depends on the distance and reflectance.</p><p></p><p>In my experience if the flash is powerful enough for the subject distance then use</p><p>. ISO 100</p><p>. Spot Meter</p><p>. Single point AF</p><p></p><p>That will give consistent flash exposure irrespective of the ambient. In case the ambient light is more, you can use Matrix metering and the flash will fill the shadows.</p></blockquote><p></p>
[QUOTE="aroy, post: 573248, member: 16090"] The flash behaves differently in different Exposure modes at least in my D3300 (and I think it will do so in most current bodies) . When using Auto ISO, in Matrix mode, as the camera uses flash as a "Fill Flash" (default setting), the body calculates the exposure for ambient light hence high ISO. At fixed ISO this is not the problem, as the flash will output enough power to light the scene. . In Spot mode the flash works as a TTL flash, its power depends on the distance and reflectance. In my experience if the flash is powerful enough for the subject distance then use . ISO 100 . Spot Meter . Single point AF That will give consistent flash exposure irrespective of the ambient. In case the ambient light is more, you can use Matrix metering and the flash will fill the shadows. [/QUOTE]
Nikon DSLR Cameras
D7200
