Nikon DSLR Cameras
D5100
view finder focus less accurate than live view.
<blockquote data-quote="Philnz" data-source="post: 77623" data-attributes="member: 8367"><p>You talk about single point focus and using live view to set it. When using the view finder you can move the single point focus point the same as you would in live view. If you look in the view finder you will see a grid of black dots One will be red which is the focus point. You can adjust it's position to be over the the part of the photo you want in sharp focus. Does this help?</p></blockquote><p></p>
[QUOTE="Philnz, post: 77623, member: 8367"] You talk about single point focus and using live view to set it. When using the view finder you can move the single point focus point the same as you would in live view. If you look in the view finder you will see a grid of black dots One will be red which is the focus point. You can adjust it's position to be over the the part of the photo you want in sharp focus. Does this help? [/QUOTE]
Nikon DSLR Cameras
D5100
