Flashes
Using external flash without TTL, can I still leave camera flash control in TTL mode?
<blockquote data-quote="WayneF" data-source="post: 631305" data-attributes="member: 12496"><p>The camera flash control menu (saying TTL, Manual, or Commander) is ONLY for the internal flash. It does not matter what it says if the internal flash door is shut, it is unused then. External flashes provide their own mode menu, or are Manual flash only. Camera also needs to be in its Manual mode if a Manual flash is used. The manual flash cannot follow changes to aperture or ISO.</p></blockquote><p></p>
[QUOTE="WayneF, post: 631305, member: 12496"] The camera flash control menu (saying TTL, Manual, or Commander) is ONLY for the internal flash. It does not matter what it says if the internal flash door is shut, it is unused then. External flashes provide their own mode menu, or are Manual flash only. Camera also needs to be in its Manual mode if a Manual flash is used. The manual flash cannot follow changes to aperture or ISO. [/QUOTE]
Flashes
