Nikon DSLR Cameras
D5100
Using a remote speedlight trigger with my D5100
<blockquote data-quote="skene" data-source="post: 324200" data-attributes="member: 13155"><p>did you set the flash to manual mode?</p><p>did you set the dipswitches so that they recognize each other. Usually you press the button to see if it will trigger the flash. If the flash is set on TTL mode, it will not recognize the signal and thus not fire.</p></blockquote><p></p>
[QUOTE="skene, post: 324200, member: 13155"] did you set the flash to manual mode? did you set the dipswitches so that they recognize each other. Usually you press the button to see if it will trigger the flash. If the flash is set on TTL mode, it will not recognize the signal and thus not fire. [/QUOTE]
Nikon DSLR Cameras
D5100
