Other Photography Equipment
Travel Tripod help: Thoughts on the Manfrotto Befree Advanced and Mefoto Roadtrip?
<blockquote data-quote="Needa" data-source="post: 671808" data-attributes="member: 37799"><p>Twisting, you could see the lens move from its original position and back again, but like I said it was in sand certainly not your most stable surface.</p><p></p><p> Just need to make sure you tighten them up enough.</p></blockquote><p></p>
[QUOTE="Needa, post: 671808, member: 37799"] Twisting, you could see the lens move from its original position and back again, but like I said it was in sand certainly not your most stable surface. Just need to make sure you tighten them up enough. [/QUOTE]
