Thank you!!Looking good!
I think that was my uploading lolWeird. You shutter speed seems to affect landscape/portrait orientation.![]()
Well..let's see. I shot in sports mode. ( he was playing with my two year old,they were all over the place,and i wanted the movement)Adjusted my Iso...between 400- 1600 until I found what I liked for the shot according to his position or movement. I also adjusted my aperture and shutter speeds. I can't recall what it was set to while I shot,but visually it seemed OK to me so I kept going. I got a couple of blurs and some were overexposed, and finally I found settings that seemed OK to keep shooting with. A few times he would look my way and continue on with my son,I stayed with my target and adjusted accordingly until it looked right. If that makes sense,my explanation seems winded..Why don't you tell us what the experiment was, and what your conclusions were?![]()
Yes these were uploaded directly from the camera. What is wb?You might want to up your shutter speed. All three shots are very soft and out of focus. Are these straight out of camera? The WB is very much on the warm side.
Could that be a result from me uploading them from the camera to my phone I selected recommended sizing?The exif info does not show up on any or your shots which means you probably did not process them in a way that stripped it off. When you process your photo make sure to crop them to no more than 1000 px on the long side.
Sent from my SAMSUNG-SGH-I337 using Tapatalk
It would help if you knew what camera you are using and also we need the EXIF data in able to help you.
If you fill out your profile and add the camera gear we can better answer any questions that you might have.
Under camera just put the model number like D7100; Once you put the first letter like D you will see a list of all the cameras in the database pop up. The more numbers you put in the smaller the list becomes. When you see your camera just click on it, Be sure to click on "Save Changes" in the lower right corner.
Thanks
What is wb?
Thank you..I figured that's what is was.White Balance.
This is in the D3300 forum Don.
Thank you. Well I had been in auto or programmed modes but I am wanting to get away from that. I research and then experiment. I've overexposed,underexposed,blurred etc. I just continue to shoot and adjust and try to figure what works with what to get a desired look. I will look this site over,hopefully I learn something there. Thanks again.White balance. I'm assuming that you are using your D3300 as a point and shoot camera. It is fine to do that if you don't want to go beyond that, but if you want to get the full benefit of a DSLR camera, then learning and starting from the basics is a must.
Here is a very useful website that I learned a ton from when I started, and still rely on it now.
Digital Photography School - Digital Photography Tips and Tutorials
Very easy to follow and learn.
