Nikon DSLR Cameras
D3200
Settings Advice
<blockquote data-quote="aroy" data-source="post: 292110" data-attributes="member: 16090"><p>I would suggest that you shoot in RAW. The basic software - View NX is free and supplied with the camera. Download it if you do not have it.</p><p></p><p>Secondly try to be away from the 55mm end of 18-55 (limit your self to 40-45mm). Similarly is possible avoid the 200mm end and try to be within 150mm. The reason is that though they are not bad, the longer ends of both zooms are a bit soft, so that your photographs are not as sharp as they can be.</p><p></p><p>The utility of a sharp lense is that you can then use the full power of the 24MP sensor.</p><p></p><p>[ATTACH]82983[/ATTACH]</p><p>This is a 100% crop, taken with the 50mm prime. Note how sharp it is even though blown up a lot. That is the advantage of a high MP sensor. With proper lense you can crop the hell out of it and still get a decent image.</p></blockquote><p></p>
[QUOTE="aroy, post: 292110, member: 16090"] I would suggest that you shoot in RAW. The basic software - View NX is free and supplied with the camera. Download it if you do not have it. Secondly try to be away from the 55mm end of 18-55 (limit your self to 40-45mm). Similarly is possible avoid the 200mm end and try to be within 150mm. The reason is that though they are not bad, the longer ends of both zooms are a bit soft, so that your photographs are not as sharp as they can be. The utility of a sharp lense is that you can then use the full power of the 24MP sensor. [ATTACH=CONFIG]82983._xfImport[/ATTACH] This is a 100% crop, taken with the 50mm prime. Note how sharp it is even though blown up a lot. That is the advantage of a high MP sensor. With proper lense you can crop the hell out of it and still get a decent image. [/QUOTE]
Nikon DSLR Cameras
D3200
Settings Advice
