Nikon DSLR Cameras
D7000
Setting aperture on a D7000 with a reverse ring
<blockquote data-quote="shibang" data-source="post: 94388" data-attributes="member: 9462"><p>Hi All,</p><p></p><p></p><p>Does anybody know how to manually set the aperature on a lens with a reverse ring on a D7000?</p><p></p><p>At the moment I can only move the little prong thing on the lens and hold it in place with some tape.</p><p></p><p></p><p>I was watching a guide where a Canon body was being used.</p><p></p><p></p><p>This person put the lens on the body, set the aperature to f/8, pressed the dof preview button and while holding the button he removed the lens.</p><p></p><p></p><p>This left the lens set at f/8 and then he could mount the lens back on the body with a reverse ring.</p><p></p><p></p><p>If I try this on the D7000, when I remove the lens I see the blades close like the lens is back at f/22 or there abouts.</p><p></p><p></p><p>Regards,</p></blockquote><p></p>
[QUOTE="shibang, post: 94388, member: 9462"] Hi All, Does anybody know how to manually set the aperature on a lens with a reverse ring on a D7000? At the moment I can only move the little prong thing on the lens and hold it in place with some tape. I was watching a guide where a Canon body was being used. This person put the lens on the body, set the aperature to f/8, pressed the dof preview button and while holding the button he removed the lens. This left the lens set at f/8 and then he could mount the lens back on the body with a reverse ring. If I try this on the D7000, when I remove the lens I see the blades close like the lens is back at f/22 or there abouts. Regards, [/QUOTE]
Nikon DSLR Cameras
D7000
