Computers and Software
s/w to "cut" differences between images
<blockquote data-quote="aroy" data-source="post: 319892" data-attributes="member: 16090"><p>Though I cannot pin point the relevant software, there are image processing software which do just what you want. In fact adding, subtracting and blending is a routine affair in these software. Just search the net for them. In my case I mostly write my own software for satellite image processing (that is how I got to know what you want).</p><p></p><p>Some software will do blind operations, that is they expect every thing to be aligned, while more advanced one do pattern recognition and scale-align-colour match before carrying out these operations.</p><p></p><p>I hope that this helps you.</p><p></p><p>Here are some useful links</p><p></p><p><a href="http://www.siox.org/" target="_blank">SIOX: Simple Interactive Object Extraction</a></p><p><a href="http://www.artisteer.com/?p=extracting_objects" target="_blank">Extracting Objects From Images</a></p></blockquote><p></p>
[QUOTE="aroy, post: 319892, member: 16090"] Though I cannot pin point the relevant software, there are image processing software which do just what you want. In fact adding, subtracting and blending is a routine affair in these software. Just search the net for them. In my case I mostly write my own software for satellite image processing (that is how I got to know what you want). Some software will do blind operations, that is they expect every thing to be aligned, while more advanced one do pattern recognition and scale-align-colour match before carrying out these operations. I hope that this helps you. Here are some useful links [url=http://www.siox.org/]SIOX: Simple Interactive Object Extraction[/url] [url=http://www.artisteer.com/?p=extracting_objects]Extracting Objects From Images[/url] [/QUOTE]
