Nikon DSLR Cameras
D5100
Rapid Fire Shots in Manual Mode - Is it possible?
<blockquote data-quote="Lee532" data-source="post: 321473" data-attributes="member: 17013"><p>As we are in the D5100 forum I guess you are asking about that body. Yes you can use continuous shutter in manual. If I remember correctly press the i info button to get in to menu and scroll down to release mode and select continuous. I used a class 10 SD card any got around 15/20 RAW shots before the buffer filled up. Do I not miss menus!</p></blockquote><p></p>
[QUOTE="Lee532, post: 321473, member: 17013"] As we are in the D5100 forum I guess you are asking about that body. Yes you can use continuous shutter in manual. If I remember correctly press the i info button to get in to menu and scroll down to release mode and select continuous. I used a class 10 SD card any got around 15/20 RAW shots before the buffer filled up. Do I not miss menus! [/QUOTE]
Nikon DSLR Cameras
D5100
