Other Photography Equipment
PROpad for Capture Camera Clip First Impressions
<blockquote data-quote="Bill16" data-source="post: 527768" data-attributes="member: 15356"><p>Have you guys tried the Spider holster pro? It tends to work very well and you can get a pro clamp to clamp onto your L bracket if you want. The only real down side that I have found is that in can cost a lot to get it just the way I wanted it. I have the double holster, but have only bought one pro clamp for a L bracket. And even so I'm still have hundreds of dollars invested. $200.00 for the double holster spider pro and $100.00 for the added L bracket clamp. So I still have $100.00 to go before it is completed the way I want it.</p><p></p><p>But if money isn't a real big issue, these spider pro holsters are very good and very strong.<img src="data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7" class="smilie smilie--sprite smilie--sprite1" alt=":)" title="Smile :)" loading="lazy" data-shortname=":)" /></p></blockquote><p></p>
[QUOTE="Bill16, post: 527768, member: 15356"] Have you guys tried the Spider holster pro? It tends to work very well and you can get a pro clamp to clamp onto your L bracket if you want. The only real down side that I have found is that in can cost a lot to get it just the way I wanted it. I have the double holster, but have only bought one pro clamp for a L bracket. And even so I'm still have hundreds of dollars invested. $200.00 for the double holster spider pro and $100.00 for the added L bracket clamp. So I still have $100.00 to go before it is completed the way I want it. But if money isn't a real big issue, these spider pro holsters are very good and very strong.:) [/QUOTE]
