Computers and Software
Problem with connection between PC and camera
<blockquote data-quote="aroy" data-source="post: 356892" data-attributes="member: 16090"><p>If it was working in past, and stopped working now, the culprit is most probably the cable.</p><p>. If you have more than one USB port, change the port and see if it works.</p><p>. If it does not, try another cable with the same connecter.</p><p>. If there are more than one computer then try on another one.</p><p>. If it still does not work, then may be the USB interface in the camera is gone.</p></blockquote><p></p>
[QUOTE="aroy, post: 356892, member: 16090"] If it was working in past, and stopped working now, the culprit is most probably the cable. . If you have more than one USB port, change the port and see if it works. . If it does not, try another cable with the same connecter. . If there are more than one computer then try on another one. . If it still does not work, then may be the USB interface in the camera is gone. [/QUOTE]
