Problem Using Telescope Adapter
Drum
Hi. I have an adapter to fit my camera to the telescope for astrophotography. I have set to Manual and I can focus an image on the LCD screen, but, when I hit the shutter, it sounds ok, but is only producing a blank image. The adapter is literally just the necessary metalwork to attach the two and has no circuitry of its own.
Can anyone shed light?
Drum
I'm photographing the moon, which appears very bright on the LCD, but even daylight photos are just blank. I've deleted the duds, but I'll try again and post the results.
Drum
Actually, I return sheepishly to admit that the shutter speed was set so inordinately high that nothing was ever going to show. More sensible speeds gave me an image, though a blurry one as I can't work out how to focus. The scope itself lets me get so far, but never quite makes focus.
​has anyone here done any astrophotography and can offer any guidance to a complete newbie?
Try focusing in Live View mode, and zoom the LCD display to extremely enlarge the subject so you can see it well (or a tiny part of it well). Then you can turn Live View off (or not), the camera cannot otherwise change the telescope focus.
sOnIc
Hi Drum. I don't know about your blank image problem, but I've done Moon images using a D50 mounted prime-focus on a Meade ETX-105 (1470mm/F14) and despite all that light I found it hard to get sharp images with a single shot, mainly because of atmospheric wobble but also when you are 'zoomed in' on the Moon it moves pretty quickly. That was without the motors in the scope going; just using it as a lens - my scope's mount isn't strong enough to run motors while supporting the weight of an SLR, thus light-weight CCD cams are preferred.
Most astrophotography like this is done by stacking multiple exposures using software like Registax or Meade's Envisage software. My best lunar image is a mosaic of 35 multi-stacked images using Meade's LPI CCD imager with motorized software telescope tracking, this means you see the live image on a computer screen and it stacks exposures real time; binning any which are below a quality threshold. You draw a box around a bright spot on the Moon and the telescope tracks that spot! Stacking, in this case, is mainly about undoing the atmospheric wobble; like heat haze.
But still; you should be able to get something pleasing with a basic setup, what scope/mount do you have etc?
Full moon is rubbish; no shadows in the craters and thus no detail; you want anything but full moon, and you want it high in the sky so there is less atmosphere between you and your subject; less coloration and heat haze etc.
(I've logged my progress over the years on my website; see the astrophotography page : )
EDIT: "The scope itself lets me get so far, but never quite makes focus." - is this actually the reality? It should go beyond good focus; just like any lens. Did you buy an adapter designed for your setup? If the adapter was sold for your scope then you should be fine I guess, but if you can't reach focus then you're never going to get a decent image, possible an extender tube would fix it; but ... .. and I do remember that the focus required for an SLR on the rear port is very different to the focus for an eye-piece in the top port - requiring a lot of turns of the focus knob; and not easy to see exactly which way to go! That could be a lot of your problem?
