Nikon DSLR Cameras
D7000
pc firmware
<blockquote data-quote="LouCioccio" data-source="post: 119785" data-attributes="member: 12542"><p>No. What I did was save the settings on two different sd cards (they don't have to be large 1GB or 2GB) and you can save those setting. I did one for Portrait and the other for Landscape. The down side is Nikon gives a default filename rather than have the user give it a name like Portrait.xxx. You would think they could have done as they allow you to change other things with their alpha numeric software keyboard in the menu.</p><p>Anyway I put a small tag on each card and flipped the lock button so I can't accidentally write to it.</p><p></p><p>Then you can load them to U1 and U2 it does work.</p><p></p><p>Ciao,</p><p>Lou Cioccio</p></blockquote><p></p>
[QUOTE="LouCioccio, post: 119785, member: 12542"] No. What I did was save the settings on two different sd cards (they don't have to be large 1GB or 2GB) and you can save those setting. I did one for Portrait and the other for Landscape. The down side is Nikon gives a default filename rather than have the user give it a name like Portrait.xxx. You would think they could have done as they allow you to change other things with their alpha numeric software keyboard in the menu. Anyway I put a small tag on each card and flipped the lock button so I can't accidentally write to it. Then you can load them to U1 and U2 it does work. Ciao, Lou Cioccio [/QUOTE]
Nikon DSLR Cameras
D7000
pc firmware
