Nikon DSLR Cameras
D600/D610
Old flashes - need help
<blockquote data-quote="WayneF" data-source="post: 276197" data-attributes="member: 12496"><p>It may just be syntax, but there is no "charging cable". They call it a charging port, but the TT560 power port supports an external battery pack. </p><p> </p><p>This external power pack does NOT charge the batteries. It is a high voltage power converter (around 300 volts DC) which charges the flash capacitor directly for faster recycle and longer battery life. It works in parallel with the regular power converter built into the flash unit (both recycle the capacitor, faster).</p></blockquote><p></p>
[QUOTE="WayneF, post: 276197, member: 12496"] It may just be syntax, but there is no "charging cable". They call it a charging port, but the TT560 power port supports an external battery pack. This external power pack does NOT charge the batteries. It is a high voltage power converter (around 300 volts DC) which charges the flash capacitor directly for faster recycle and longer battery life. It works in parallel with the regular power converter built into the flash unit (both recycle the capacitor, faster). [/QUOTE]
Nikon DSLR Cameras
D600/D610
