Photography Q&A
Nikon D5300 producing black images after using macro extension
<blockquote data-quote="J-see" data-source="post: 426190" data-attributes="member: 31330"><p>I assume the D5300 has no exposure preview and what you see on the LCD is the same as what is in the viewfinder. If you want that image, you still have to set the exposure correctly.</p><p></p><p>Try setting it to a long duration shutter like 10 seconds or more. If exposure is the problem, it should no longer be black and possible be overexposed. If needed set ISO high too. Now you see the image through the lens while constantly open which is something else completely than a shot which is only exposed a limited amount of time.</p></blockquote><p></p>
[QUOTE="J-see, post: 426190, member: 31330"] I assume the D5300 has no exposure preview and what you see on the LCD is the same as what is in the viewfinder. If you want that image, you still have to set the exposure correctly. Try setting it to a long duration shutter like 10 seconds or more. If exposure is the problem, it should no longer be black and possible be overexposed. If needed set ISO high too. Now you see the image through the lens while constantly open which is something else completely than a shot which is only exposed a limited amount of time. [/QUOTE]
Photography Q&A
