Post Processing
Need help with consistent white balance?
<blockquote data-quote="STM" data-source="post: 614107" data-attributes="member: 12827"><p>Skin tones are a <em>very poor </em>choice of source for white balance adjustment because they are infinitely variable when it comes to tone. I am unfamiliar with the program you are using in but in Photoshop the Adjustments tool has a tool to adjust color balance when used with an area in the image that is either white or a neutral gray. This is the area you should find in your image to adjust color balance.</p></blockquote><p></p>
[QUOTE="STM, post: 614107, member: 12827"] Skin tones are a [I]very poor [/I]choice of source for white balance adjustment because they are infinitely variable when it comes to tone. I am unfamiliar with the program you are using in but in Photoshop the Adjustments tool has a tool to adjust color balance when used with an area in the image that is either white or a neutral gray. This is the area you should find in your image to adjust color balance. [/QUOTE]
Post Processing
