Education
Need a camera and fully confused
<blockquote data-quote="RocketCowboy" data-source="post: 639856" data-attributes="member: 25095"><p>Good call [USER=43990]@sampochin[/USER] on the D750! That's an excellent camera as well, and will probably carry you well into whatever Nikon releases to replace the D850. I'm right there with you though on buying latest tech! <img src="data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7" class="smilie smilie--sprite smilie--sprite2" alt=";)" title="Wink ;)" loading="lazy" data-shortname=";)" /></p><p></p><p></p><p></p><p>Exactly right. The other benefit to that 50mm f/1.4 prime is that it's smaller and lighter than the 24-70mm f/2.8 lens. The downside being that if you need to zoom in or out, you're using your legs to do it.</p></blockquote><p></p>
[QUOTE="RocketCowboy, post: 639856, member: 25095"] Good call [USER=43990]@sampochin[/USER] on the D750! That's an excellent camera as well, and will probably carry you well into whatever Nikon releases to replace the D850. I'm right there with you though on buying latest tech! ;) Exactly right. The other benefit to that 50mm f/1.4 prime is that it's smaller and lighter than the 24-70mm f/2.8 lens. The downside being that if you need to zoom in or out, you're using your legs to do it. [/QUOTE]
Education
