Minimum shutter speed level breached
Vikas Chander
Hello,
sorry if this question has been asked elsewhere on the forum , i tried to look for it but could not find any relevant post.
I want to shoot some sunset timelaspes on my nikon d810a.
So i go about setting the Auto Iso to on and put the camera in aperture priority.
The interval for the timelapse is set 7 seconds
Max iso is set 3200 and the minimum shutter speed to 4 secs.
I start the timelapse and the shutter speed slowly increases to 4 seconds and after that the iso increases to 3200.
At this point i expect no further changes to the shutter or the ISO , but then the shutter speed starts increasing again till it reaches 10 seconds.
So my question - Is there any setting which will prevent the shutter speed to drop beyond the minimum shutter speed value?
cheers
vikas chander
Danno_RIP
Welcome to the forum Vikas. I am sure you will get some insight into how to set up this shot. I think when you set it on aperture priority what you are seeing is inevitable. But there are a number of folks here that do time laps.
Scott Murray
Hello,
cheers
vikas chander
Use manual and then adjust as needed, I have done this with a sunset to moonrise timelapse and yes it is time consuming but is also doable. PS your shutter was decreasing.. You never mentioned what setting you used. I would be using S for shutter speed as you can only go down to the widest A which I am guessing you would have been using.
Vikas Chander
hi
my starting settings were iso 200 and 1/4000 with aperture at f2.8. The end exposure required by me was 4 secs and iso 3200 at f2.8 . I set the intervalometer to 7 secs hoping to get a nice holy grail sunset to citylights/stars timelapse.
Yes i can do the manual method but that always ends up with a lot of flicker requiring deflickering in LRTimelapse not to mention the inevitable camera shake.
So , i want to use a totally hands free post free workflow ...
vikas
Scott Murray
hi
vikas
This was done the way that I said eg Manually, I never got the camera shake that you mentioned. Also this was my very first attempt. I used a D800E.
