Totally normal. That's the camera writing the photo data to the card.
Most importantly, it's the "Don't turn the camera off while I'm on or blinking" light.
Actually, it is computer controlled, and the camera will not turn off until the buffer is written to the card. However, one could remove the card, or remove the battery or AC power, and make writing fail.
I'll defer to the manual under Memory Card cautions.![]()
Sounds good. Mine says:
"Do not remove the memory card or remove or disconnect the power source
until the access lamp has gone out. If the camera is switched off while
data remain in the buffer, the power will not turn off until all images in
the buffer have been recorded. If the battery is exhausted while images
remain in the buffer, the shutter release will be disabled and the images
transferred to the memory card."
run4fun did not specify, but I assumed he was referring to his D7100. I must admit though, that I've learned not to believe everything I read.
.........The programmers would have done a pretty poor job if they allowed the camera to be turned off while writing the card (or while actively doing anything actually).
I see your point
Now I know not only to not turn the camera off if the light is lit, but it's okay to turn it off if the light is lit while the camera is writing to the card from the buffer.
You seem to perceive a difference where I don't. The card is only written from the buffer.![]()
Is the writing of files from the buffer the only time files on the card are accessed?
Writing, yes, that is my opinion. The camera creates the file, buffers it, and the buffer is written to the card. The buffer may only have one image in it most times. But there would not be two procedures created to write an image to the card.
Reading is something else, no damage done if reading is interrupted. But reading is one image, and fast, and I'd guess it waits for all operations to complete before turning off the camera. Why not?
What about when reading a movie file?
OK, maybe an exception, but reading is not destructive (does not change anything), so I imagine it just quits then.
What about writing a movie file?It buffers frames (and writes blocks or sectors), so I imagine it just chooses a good stopping point, and does any necessary tidying up. File is terminated, but not destroyed.
But I doubt the Off switch is an interrupt, it just quits when it loops back around to check it. And surely tidies up first.
So, any other question would have the same answer, which I suppose in summary is that we can disregard the Memory Card cautions, but if I understand your comments there is some imagination and doubt mixed into the general idea.
I imagine the green light has a purpose and doubt I'll put it to a test.![]()
