Flashes
max flash sync speed
<blockquote data-quote="aroy" data-source="post: 451801" data-attributes="member: 16090"><p>There is a work around.</p><p>. Set your mode to "S", speed to 200 and ISO to 100. The aperture will now be the only variable.</p><p>. Fit and ND filter and set the exposure compensation accordingly. If the ND is 3EV, then set the compensation to +3EV.</p><p></p><p>If the camera does no TTL, then the Exposure compensation should give you proper exposure. If the TTL works, then you do not need to set the exposure compensation.</p></blockquote><p></p>
[QUOTE="aroy, post: 451801, member: 16090"] There is a work around. . Set your mode to "S", speed to 200 and ISO to 100. The aperture will now be the only variable. . Fit and ND filter and set the exposure compensation accordingly. If the ND is 3EV, then set the compensation to +3EV. If the camera does no TTL, then the Exposure compensation should give you proper exposure. If the TTL works, then you do not need to set the exposure compensation. [/QUOTE]
Flashes
