Nikon DSLR Cameras
Out of Production DSLRs
D50/Z50ii
Massive error with pictures....Help
<blockquote data-quote="markwilliams279" data-source="post: 114320" data-attributes="member: 12675"><p>you can remove the lens from the camera, set the lens to the smallest aperture, and use the lock button to hold it there. Re-connect the lens, turn the camera back on, and all should be well. If you are still facing an error then you can also try another memory card to save your photos. It may be your current memory card got corrupt.</p></blockquote><p></p>
[QUOTE="markwilliams279, post: 114320, member: 12675"] you can remove the lens from the camera, set the lens to the smallest aperture, and use the lock button to hold it there. Re-connect the lens, turn the camera back on, and all should be well. If you are still facing an error then you can also try another memory card to save your photos. It may be your current memory card got corrupt. [/QUOTE]
Nikon DSLR Cameras
D50/Z50ii
