Other Photography Equipment
Manfrotto Gear Head
<blockquote data-quote="pendennis" data-source="post: 570745" data-attributes="member: 42413"><p>I've used the 410 with both large and medium format. Right now, it's on a Bogen 3221, but I've also used in on an older Bogen 3036. Just to be anal, I also attached a 5 lb counterbalance on the geared post.</p><p></p><p>The 410 is a very handy head. I like the fine gearing, but I can also use the coarse controls to move the head quickly. And you are absolutely correct; there's no backlash on the gears.</p><p></p><p>Good luck, and I think you'll really enjoy it.</p></blockquote><p></p>
[QUOTE="pendennis, post: 570745, member: 42413"] I've used the 410 with both large and medium format. Right now, it's on a Bogen 3221, but I've also used in on an older Bogen 3036. Just to be anal, I also attached a 5 lb counterbalance on the geared post. The 410 is a very handy head. I like the fine gearing, but I can also use the coarse controls to move the head quickly. And you are absolutely correct; there's no backlash on the gears. Good luck, and I think you'll really enjoy it. [/QUOTE]
Manfrotto Gear Head
