Computers and Software
Lightroom- Why does auto white balance no longer work after changing camera profile?
<blockquote data-quote="paul_b" data-source="post: 225117" data-attributes="member: 15676"><p>So, have i understood this all correctly then (at least for my D3100):</p><p></p><p>'Adobe standard' is recommended because the white balance controls in Lightroom work as Adobe intended (i.e 'as shot', 'flash' etc). </p><p></p><p>However, if i want to use the Nikon profiles Adobe have made i.e 'camera standard' etc then the only way to adjust the white balance is either manually (temp & tint sliders) or with the 'white balance picker tool', and the white balance needs to be started off 'as shot' and then adjusted manually.</p><p></p><p>So in theory, neutral is neutral for both 'adobe standard' and say 'camera standard' and thus the 'white balance picker tool' works the same for both.</p></blockquote><p></p>
[QUOTE="paul_b, post: 225117, member: 15676"] So, have i understood this all correctly then (at least for my D3100): 'Adobe standard' is recommended because the white balance controls in Lightroom work as Adobe intended (i.e 'as shot', 'flash' etc). However, if i want to use the Nikon profiles Adobe have made i.e 'camera standard' etc then the only way to adjust the white balance is either manually (temp & tint sliders) or with the 'white balance picker tool', and the white balance needs to be started off 'as shot' and then adjusted manually. So in theory, neutral is neutral for both 'adobe standard' and say 'camera standard' and thus the 'white balance picker tool' works the same for both. [/QUOTE]
