Computers and Software
LightRoom - Super FRUSTRATION - Help!
<blockquote data-quote="BackdoorArts" data-source="post: 277517" data-attributes="member: 9240"><p>I'm out of theories. Time for a chat with tech support - good luck!!</p><p></p><p>Worse comes to worse, you can embed the catalog information into the RAW files and then import them fresh into a new catalog from the photos. The embedded information should also import into the new catalog. It's going to be time consuming, but if you have some sort of corruption then this may be the only way to do it and save your edits. I'd try it on a small set of pics first, but only after I exhausted all other possibilities.</p></blockquote><p></p>
[QUOTE="BackdoorArts, post: 277517, member: 9240"] I'm out of theories. Time for a chat with tech support - good luck!! Worse comes to worse, you can embed the catalog information into the RAW files and then import them fresh into a new catalog from the photos. The embedded information should also import into the new catalog. It's going to be time consuming, but if you have some sort of corruption then this may be the only way to do it and save your edits. I'd try it on a small set of pics first, but only after I exhausted all other possibilities. [/QUOTE]
