Nikon DSLR Cameras
D5100
issues with my 5100
<blockquote data-quote="nickt" data-source="post: 702238" data-attributes="member: 4923"><p>Failure to fire without a message is usually when the camera does not see focus. Switch your lens to Manual focus. I don't know what lens you have, but it should have an af/m switch. Switching it to M will tell your camera not to worry about focus. If that works, switch it back to af and try it. Make note if the camera is attempting to focus. You can just half press your shutter and listen/watch for the focus motor. See if the motor is attempting to focus and never finds it or see if it never moves at all. Try removing and reinstalling your lens. Make sure it clicks into place. Check that it is secure by gently trying to tighten/loosen it while you are <strong>not</strong> pressing the release button. If you have another lens, try it.</p><p>I suspect your lens is not focusing. Sometimes randomly pointing the camera around lets it see <em>something</em> in focus and the camera will fire on those occasions. Otherwise, it does not see focus and won't fire.</p></blockquote><p></p>
[QUOTE="nickt, post: 702238, member: 4923"] Failure to fire without a message is usually when the camera does not see focus. Switch your lens to Manual focus. I don't know what lens you have, but it should have an af/m switch. Switching it to M will tell your camera not to worry about focus. If that works, switch it back to af and try it. Make note if the camera is attempting to focus. You can just half press your shutter and listen/watch for the focus motor. See if the motor is attempting to focus and never finds it or see if it never moves at all. Try removing and reinstalling your lens. Make sure it clicks into place. Check that it is secure by gently trying to tighten/loosen it while you are [B]not[/B] pressing the release button. If you have another lens, try it. I suspect your lens is not focusing. Sometimes randomly pointing the camera around lets it see [I]something[/I] in focus and the camera will fire on those occasions. Otherwise, it does not see focus and won't fire. [/QUOTE]
Nikon DSLR Cameras
D5100
issues with my 5100
