Photo Evaluation
Photo Feedback
Images not in focus, not sharp and color is strange
<blockquote data-quote="BackdoorArts" data-source="post: 213285" data-attributes="member: 9240"><p>There is no DX crop factor/effective focal length adjustment with this rule. For example, say you have an 85mm full frame lens. If you have to shoot at a minimum of 1/85 sec (w/o VR) on an FX camera to prevent movement then the entire frame, from the center to outer edges, is covered. Had you been shooting the same camera in DX mode the rules would not have changed.</p></blockquote><p></p>
[QUOTE="BackdoorArts, post: 213285, member: 9240"] There is no DX crop factor/effective focal length adjustment with this rule. For example, say you have an 85mm full frame lens. If you have to shoot at a minimum of 1/85 sec (w/o VR) on an FX camera to prevent movement then the entire frame, from the center to outer edges, is covered. Had you been shooting the same camera in DX mode the rules would not have changed. [/QUOTE]
Photo Evaluation
Photo Feedback
