Nikon DSLR Cameras
D5200
How to reduce ambient light without effecting flash light in d5200 for outdoor portra
<blockquote data-quote="spb_stan" data-source="post: 662374" data-attributes="member: 43545"><p>The problem with ND is having to use a tripod since you need to focus without the filter in place or manually focus. How bright is ambient light? Bright sunlight still might be bright enough for auto or manual focusing. Do you really need razor thin DOF? By adjusting the ratio of the camera to subject and subject to background you may find you can get pleasant out of focus rendering if you are a lot closer to the subject than the subject to the background is. That way you could stop down some and get better lens performance at f/4.0 or 5.6. You could also go the other way with overexposing the background for High-Key lighting by having the subject in shadows and properly exposed and the bright background would fully white out by being over-exposed</p></blockquote><p></p>
[QUOTE="spb_stan, post: 662374, member: 43545"] The problem with ND is having to use a tripod since you need to focus without the filter in place or manually focus. How bright is ambient light? Bright sunlight still might be bright enough for auto or manual focusing. Do you really need razor thin DOF? By adjusting the ratio of the camera to subject and subject to background you may find you can get pleasant out of focus rendering if you are a lot closer to the subject than the subject to the background is. That way you could stop down some and get better lens performance at f/4.0 or 5.6. You could also go the other way with overexposing the background for High-Key lighting by having the subject in shadows and properly exposed and the bright background would fully white out by being over-exposed [/QUOTE]
Nikon DSLR Cameras
D5200
