I've started this thread to see what others think. I've had several electronic cameras over the years and I am currently on the D750. But I'm finding the problem of sensor dynamic range, does not seem to have vastly improved. A captured image with blown highlights, like bad focus, cannot be recovered in post.
I distinguish exposure and all the fancy options first, because they are not a magic bullet. The camera sensor has a (limited) dynamic range window to capture the brightest highlight to the darkest low light. The exposure options only move that 'window' with its fixed sensitivity limits up and down. You can get crushed highlights and normally exposed middle and low lights, or dark underexposed low lights and perfect undistorted (clipped) highlights.
But I don't have the same experience so much when I use a pro video camera, so what is going on? Now some could say I'm just a lousy photographer and don't know how to use the camera. Take a landscape with a bright blue sky with lots of cumulus cloud detail with plenty of scene contrast. I want the clouds unclipped not blown and the foreground bright and not underexposed. Even cheap handycam video cameras seem to cope.
I take my landscape example and rattle off some bracketed shots with the D750 picking the shot that is not clipped and with underexposed foreground. In post I can fudge the restricted dynamic range of the camera sensor by modifying the gamma curve. Video cameras have been using gamma and black lift for years to compensate for limited sensor range. But why can't my D750 and other still cameras do this?
I read about the D750 using multiple exposure points in matrix mode, but somebody tell me, is the camera merely selecting the best 'average' exposure for the scene or is it using that matrix of information to modify the gamma curve? I don't think so since the matrix is confined to the central area as I understand it and not the whole image.
The Nikons have scene setting options. I've always avoided them as being a bit gimmicky trying to choose my shooting settings when I know what they should be. But am I wrong? Do scene options play with the camera gamma curve and introduce the black lift and white drop needed for a scene with lots of contrast for landscape? Modifying the gamma curve to avoid clipping is a fudge for limits on sensor performance, but I find that better than having clipped highlights and flat white sky in landscapes when there were nice cloud formations.
I know about Extended Dynamic Range and I'm interested in trying it but I would have expected the camera to do a better job with single shots. I am still a little puzzled by the camera preview which is based on 8 bit JPEG processing when the camera can shoot 14 bit RAW. If I see highlight clipping on the preview screen, does that mean it is less likely to be present on the saved RAW image? I don't expect an LCD screen to have much dynamic range, but the clip indicator should just be working on image pixels and my guess is the Nikons still work on 256 bit brightness levels, even when saving only RAW images.
