Hand strap and holster for D90 and D7000 (both with vertical grips)
daveminnich
I would like to get a hand strap and holster for my cameras, a D90 and D7000. They both have vertical battery grips. Any suggestions? I'd like to be able to leave the hand strap attached to the camera at all times so it needs to be compatible with the holster.
I was going to get a Peak Design Clutch strap but it does not appear to be compatible with vertical grips.
TKC_D500
My Lightroom class instructor had one on her D4s that should fit a gripped camera, I would think. It was a Nikon branded strap, but I have no idea if they are still available.
Daz
Well the Peak Design system uses an Arca swiss compatible tripod plate.
This plate works with their Capture clip which would fit the holster side of your requirements...
The clutch also attatches to the same tripod attachment and these can be used in conjunction with each other,
you just need to use the anchorloop on the back part of the tripod mount as shown on their website :) So that would fit that requirement :)
The clutch is adjustable to it would work with or without a grip :)
I use the mount on a portrait grip, I have used it on the D600, D7100 and now the D500 with grips on :)
