Education
Great Article On Understanding "Noise"
<blockquote data-quote="J-see" data-source="post: 557032" data-attributes="member: 31330"><p>It's not only the surface area that counts in terms of noise but the quantum efficiency and the native ISO of the sensor. My D810 as an example isn't that different from the D750 when it comes to photon noise even while its pixels are significantly smaller in surface area. The advantage it has is collecting at 64 ISO which makes up for the smaller surface area.</p><p></p><p>Btw, out of curiosity I just checked the signal quality of the D90 vs my D7200 and at ISO 200 they're both about the same; 0.8dB difference. The D90 has larger pixels but collects at 200 ISO vs the 100 ISO of the D7200.</p></blockquote><p></p>
[QUOTE="J-see, post: 557032, member: 31330"] It's not only the surface area that counts in terms of noise but the quantum efficiency and the native ISO of the sensor. My D810 as an example isn't that different from the D750 when it comes to photon noise even while its pixels are significantly smaller in surface area. The advantage it has is collecting at 64 ISO which makes up for the smaller surface area. Btw, out of curiosity I just checked the signal quality of the D90 vs my D7200 and at ISO 200 they're both about the same; 0.8dB difference. The D90 has larger pixels but collects at 200 ISO vs the 100 ISO of the D7200. [/QUOTE]
Education
