Flickr
PapaST
Re: Flicker
Flickr has changed their format recently but it's likely the same way. I pretty much click on the share button and at the bottom, select the size you want then copy HTML line listed there. Then paste the line into the text of your Nikonites post. Play around with EMBED and the HTML codes (try both) because I forget which one gives you the desired look.
PapaST
Re: Flicker
Let me try it... this is EMBED 800x534
NEVERMIND... I have it all wrong.
Try the SHARE BUTTON... then the THUMBTACK... select your size and copy the code and paste it in the Nikonites POST frame.
Jonathan
Re: Flicker
And I thought just identifying the Flickr picture to put here and then uploading the file from my computer was a bit long-winded!
Jonathan
Re: Flicker
1. Click on the window icon in the posting box (next to the film icon)
2. Select URL or browse computer
3. [In my case], browse to the required file by typing in part of its name in my photo library
4. Double-click the file
5. Click upload button
6. Double click picture in draft post
7. Select required size/placement
8. Click on post reply
Eight's my lucky number.
PapaST
Re: Flicker
Glad you did. Photobucket had a Url you just copied and pasted now Flicker I can't find that on Flicker
I just checked out my old Photobucket account. They are more intuitive... even labeling what some of the "links" are for. That's helpful for sure.
On flickr when you're looking at a pic you should see the following menu to the right
When you click on the box symbol with the arrow pointing upward/right it will give you a new menu that you can select for FB, Tumblr, Twitter, Pinterest, etc. I think that's where you'll find the Thumbtack to get the URL to insert. That's the way I've been doing it. There could be easier ways.
Kevin H
Re: Flicker
I get the FB.Tumblr etc but no thumbtack. Think I'm done posting on here
Lee532
Just copy the code in the box that appears when you click the forward, then paste the code in to the reply box on here and submit post. Your photo will appear on here.
Orchid by Lee532, on Flickr
